Mellings oil pumps
Old Feb 16, 2003 | 08:35 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Mellings oil pumps
Getting ready to order my oil pump.
What is the difference between the
Melling M55 and the M55A?
Is it just the "Z-28" spring?
The M55A costs twice as much.. (at Summit anyway)
Also, can I use my stock pick-up tube with the Mellings M55A pump?
Old Feb 16, 2003 | 08:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's it... just the spring. Get Mr Gasket part # 26, it's the same spring, it will give the same 55psi or so intead of the M55 35 psi.
Don't do that. Get a new one. Melling part # 55-S.
Put a shaft with a metal collar in it.... the plastic ones have been known to fail.... Melling part # IS-55E.
Old Feb 16, 2003 | 09:12 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Cool!
Can't find the Melling pick-up or pump shaft in either the Jegs or Summit catalogs.
Where else should I be looking?
Thx..
Old Feb 16, 2003 | 09:42 PM
Z_Ghost's Avatar
Moroso oil pump shaft Part # 22070
Old Feb 17, 2003 | 06:02 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Auto Zone
Old Feb 17, 2003 | 10:48 AM
12secRS's Avatar
I got all my Mellings oil pump parts (pump, oil pump shaft, and pick up at my local autozone.
Old Feb 20, 2003 | 07:05 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Just got back from the auto parts store. Picked up a M-55 pump, a IS-55E drive shaft and a oil pick-up tube.
The MR Gasket #26 spring is on order.
Noticed that instead of the 55-S pick-up tube I got a 55-S1.
Went to the Mellings site and found the the 2 pick-ups.
Unfortunately, all they have are pictures and no tech data.
What's the difference? Is one for a deeper sump oil pan?
The tube appears to be bent slightly different between the 2.
I'll be using the stock oil pan from a 87 GTA L-98 eng.
Old Feb 20, 2003 | 07:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Exactly, it's the sump depth.
The S-1 is wrong. The S fits these pans.
Old Feb 20, 2003 | 07:31 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Thx RB!
Back to the auto parts store...
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
