ttop flying off?
Old Feb 21, 2003 | 11:55 AM
TMoNeE's Avatar
Car: 87 Z28
ttop flying off?
Uh, lately, if I drive down the freeway my drivers side t-top starts making that sound like when you have your window cracked just a bit. Like air is getting under it...I grabbed the side where the handle is and pulled down and it stopped, then when I was going slower i pushed up on it and its got like a half inch of play up and down.. thats not good. What can I do about this, Id rather if it didnt fly off on me hah
Old Feb 21, 2003 | 12:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Adjust the little brackets that it latches to.
Old Feb 21, 2003 | 12:20 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
sounds like the pins that lock teht-top down are getting sloppy. Soln. is to go get more t-tops form a junk yard.
Old Feb 21, 2003 | 12:23 PM
Car: 88 Camaro SC
Engine: SFI'd 350
mine have the same problem... all the flex causes the t-tops to loosen. You can adjust the brakcets which will help but mine only loosened again after i did this because of how flimsy the bodies are on these t-top cars. If my car was actually worth something id get sfc's and bracing to stiffen it up.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
jaysfs
Exterior Parts for Sale
Sep 18, 2015 11:59 AM
MORREALE5
Sep 13, 2015 09:01 PM
scottmoyer
Sep 7, 2015 07:06 PM
