engine seals leaking
Old Feb 21, 2003 | 11:55 AM
hurricanerugger's Avatar
I bought this stuff that was recomended to me by a mechanic that you add to your oil when you change it. It's supposed to swell up the seals in the car so it doesn't burn oil as easy. Someone else told me that when this wears out that the seals will shrink even more. Should I use this stuff? Thanks.
Old Feb 21, 2003 | 12:26 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
im always hesitent to add stuff to the oil. The only true fix would be to fix the things taht are causing the engine to consume oil, like vavle guide seals.
Infested
May 22, 2018 11:56 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
