Truck 350 installed in friends vehicle
Old Feb 21, 2003 | 01:16 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
My friend is installing a truck 350 with tbi and wiring harness and computer in his car and we are just wondering what is the bare minimum as far as sensors to make the thing run. Can anyone help?
Old Feb 21, 2003 | 01:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Pretty much all of them.
Map, CTS, knock, O2, TPS, IAT, etc. Not too many you can leave off, and expect the ECM to still be able to tell what's going on in the world around it, well enough to meter fuel and set the ignition timing correctly.
Old Feb 21, 2003 | 02:35 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
The reason I ask is there are some we want to eliminate. We are getting rid of the a/c and smog stuff. I am aware of the IAT, ESC, Knock, O2, & Map. Don't know what CTS is. Thanks for the info.
Old Feb 21, 2003 | 03:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
CTS = Coolant Temp Sensor
TPS = Throttle Position Sensor
Old Feb 21, 2003 | 03:32 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Thanks again. I think we have all we need but now we are worried about the fuel. I told him he will have to do something about his fuel pump because he has a regular pickup in his tank and he had planned on running a manual fuel pump.
Old Feb 21, 2003 | 07:48 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
You can get away with a rotarty aftermarket pump Ive seen TBI trucks running just rotary pumps when the intank one dumped lazy SOB's.
The best thing to do would be to get a fuel tank from a latter modle 3rdgen with a tank//pump.
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
Reborn756
Sep 4, 2015 03:42 AM
NinjaNife
Aug 23, 2015 11:49 AM
squiggy2
Aug 9, 2015 09:30 PM
