can i use this fuel filter for fuel injection?
Old Feb 22, 2003 | 10:02 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
on my carb setup i have a plastic body fuel filter that just has a hose fitting on either end. will this hold up to the pressure made by a tpi pump? if not, should i get a steel body one?
Old Feb 22, 2003 | 10:03 PM
Car: '87 Camaro LT
Engine: 355 L98
here's a pic where you can sorta see it
Attached Thumbnails can i use this fuel filter for fuel injection?-pastedimage.jpg
Old Feb 23, 2003 | 01:19 AM
ERICK87Z28's Avatar
Car: 1988 IROC
Engine: 5.7 HO TPI
Transmission: 4 spd Auto
I think that the hose clamps don't grip enough to hold under the pressure generated by the fuel pump. Hence the need for the in-line fuel filter to have threaded fittings. As for the plastic filter itself...I think I would not chance it, it is made for the pressures put out by a mechanical fuel pump, obviously much less than an electrical one.
Old Feb 23, 2003 | 02:34 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
also quite dangerous... imagine that thing bursting/coming off the line with 45 psi behind it alll over a hot engine reminds me of the time a needle stuck on my carb and fuel was spurting out of the vent tube... lucklily the motor wasn't hot and I caught it right away
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
