What is required for the 90-92 Camaro speedometer/gauges to work??
Old Feb 23, 2003 | 07:50 PM
CamaroX84's Avatar
I want to put a complete 92 Camaro dash into my non-computer controlled 84 Camaro. I have a VSS in my garage that I can put on now, but where do I run the wire to make the dash work? Also, will I have a problem with the other gauges working? Thanks.
Old Feb 23, 2003 | 08:52 PM
BOTTLEDZ28's Avatar
Transmission: A4
i believe the wires from the VSS run to the ECM then to the speedo.
Old Feb 23, 2003 | 09:08 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
I did that on my '82. The problem is that the computer changes the signal before it gets to the speedo. So if you run (like me) without an ECM then you need to get a box like one from Dakota Digital that can convert the signal instead of the ECM so the speedo reads true. And on top of that it is adjustable for gear chagnes. But the box was like $80 so be prepared. The connectors for the guages are not wired correctly between the two different styles, but you can get them to work. If you have any questions on the swap I can try and help. But I think the biggest ordeal is getting the dash to physically bolt in.
Old Feb 23, 2003 | 09:25 PM
CamaroX84's Avatar
What wire on the dash harness do you have to splice that into then? Also do you have a part number for that box? The only gauge I'm concerned about is fuel level. I have Auto meter gauges for the others. Thanks again.
Old Feb 23, 2003 | 10:19 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i have stock gauges and all. i also run a non computer controlled setup without the computer (it has been compacted). speedo works fine....
Old Feb 24, 2003 | 01:56 PM
CamaroX84's Avatar
So then from what brody is saying, the speed sensor must somehow directly tie into the dash without first going through the computer. Anyone know where?? Thanks.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
squiggy2
Aug 9, 2015 09:30 PM
