1989 camaro problem
Old Feb 23, 2003 | 08:11 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
1989 camaro problem
what would cause a 1989 camaro with tbi for no reason to stop getting fuel no ecm codes but after car sits for awhile it starts right up, vats seems to be functioning corectly HELP
Old Feb 23, 2003 | 08:36 PM
KMAN's Avatar
possible fuel pump problems
Old Feb 24, 2003 | 10:00 AM
SlowStangEater's Avatar
Re: 1989 camaro problem
Are you sure its fuel related?
If it is getting hot and then sits it could be the started solenoid;
It also could be the nuetral safety switch (thats what mine was!)
We need more info...
Old Feb 24, 2003 | 04:12 PM
Jproz1167's Avatar
no this has nothing to do with the car not cranking over at all, this is what happens while driving it even on cool days, its starts to hesitate real bad then just dies, I removed the air filter lid and had someone crank the motor over and absolutely no fuel sprayed out of either injector not even a drop, the I let the car sit for ten minutes or so and it fires right up and runs fine, (fuel pump relay was replaced ) no ecm codes at all, vats tumbler was replaced and appears to be functioning right, ecm replaced, when it's running motor never skips a beat.
Old Feb 24, 2003 | 04:35 PM
hmmm, does it crank when you turn the key? Or is it just dead?
Can you hear the Fuel Pump come on when you turn the car on? That could be the cause but I dont get the car sputtering and dying... Do your gauges drop or do you see any loss in power of your accessories before the car dies?
camaro11j
Sep 19, 2018 08:49 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
Derick15
Sep 17, 2016 05:28 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
antares57
Aug 6, 2015 07:47 AM
