What compression ratio am i runnin?
Old Feb 25, 2003 | 02:28 PM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
This seems stupid, but I just put my new heads on and they were 64cc vortechs and I had them milled .030. I heard this gets a 305 close to 10 to 1. My head gasket is a real thin stainless steel that said it was.020 thick which was the thinest I could get the not so smart parts guys to find.
Any good guess would be helpfull
Old Feb 25, 2003 | 02:31 PM
ede's Avatar
ede
need to know how much in or out of the hole the piston is ,the volumn of the dish or valve reliefs plus the volumn of the head to figure it
Old Feb 25, 2003 | 03:07 PM
Car: 89 Camaro RS
Engine: 305 TBI
Well they are the stock pistons with the two small valve reliefs. They aren't full valve reliefs just the two half circles. The heads were 64 cc but I had .030 taken off of them to keep the compression close to stock which is like 9.3 to 1 i think.
Old Feb 25, 2003 | 04:59 PM
rezinn's Avatar
I don't think the milling would drop more than a couple ccs, and the gasket will have dropped about half that. I couldn't see your compression being much higher than stock, if at all, unless milling reduced the chamber size more than I think.
Old Feb 25, 2003 | 05:48 PM
Aron213's Avatar
Car: 88 Iroc
the milling would have dropped you in the 59 or 60cc range.
easy formula to get you in the ball park of what your compression is....do a compression test...say you get a reading of 155 now devide that by 15.1 then subtract 1...this would give you a compression of 9.2 to 1.
Compression test / 15.1
-1 =
compression
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
