winsheild wiper fluid pump
Old Feb 27, 2003 | 08:41 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
i just bought a 91 droptop z28 and the washer fluid pump doesnt work and the fuse is good and i bought a new pump and it still dont work so is there any relays or anything else to check before i go through the trouble of chasing down the wires
Old Feb 27, 2003 | 09:31 PM
BOTTLEDZ28's Avatar
Transmission: A4
is the pump getting 12 volts to it? Are you sure the pump isnt working or that maybe the hoses are clogged and nothing is coming out. Have a buddy, turn the washers on while you listen to see if the pump turns on. If it dont then check for 12 volts while the washer button is pushed foward. If there is no power then you have to trace the wires back.
backtothe80s
Sep 5, 2015 12:39 AM
Randomtask2
Aug 26, 2015 03:34 PM
92camaroJoe
Aug 13, 2015 06:07 AM
slade5612
Aug 11, 2015 07:19 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
