Spark plug wires
Old Feb 27, 2003 | 09:51 PM
jdrafke's Avatar
Spark plug wires
Jey guys i got some pretty old saprk plug wires in my car right now. I was just wodnering what kind of gains i can expect by putting on some new msds(there aobut 55 bucks). Or, will this just be good for the engine. Thanks
Old Feb 27, 2003 | 10:19 PM
v8unleashed's Avatar
i dont think youll see any gains unless the ones you have now are so old and shltty that they're hurting performance as is
Old Feb 28, 2003 | 05:57 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
upgraded ignition stuff doesnt increase power until you're running RPMs or compression out of the range of the factory system.
Old Feb 28, 2003 | 09:40 AM
Vader's Avatar
Instead of just guessing, test your wires with an ohmmeter. If you get more than 650 ohms/foot, they may be failing. If you need replacments, get a decent set of 8mm silicone supression wires. Carbon filaments are just fine, even for performance engines. If the old wires test O.K., clean them, apply silicone grease to the boots at each end, and reinstall them.
Old Feb 28, 2003 | 09:45 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You won't gain anything at all if the ones you have are working OK.
The usual ways that plug wires fail are either by the center conductor breaking, which Vader's test is for; or by the insulation failing and allowing the spark to "leak" out, which is what heat and age cause to happen to them.
I like the Taylor Spiro-Pro wires myself.... they fit, unlike alot of others whose boots are huge and end up against headers and things; and they come in black, so they don't turn into this gaudy thing with giant greasy handprints on them, like alot of the brightly-colored ones do.
Old Feb 28, 2003 | 01:18 PM
Steve89GTA's Avatar
Vader has a really good point.
I picked up a set of Taylor 8mm wires and 3 out of the 9 wires in there were bad. Resistance was 18K, 25, and 180k which is waaay to high. I brought them back and he hands me another box. 2 were bad in that one! (I brought my ohm meter with me).
Not sure if Taylor just had a bad run or not but I'll be sure and test them everytime I pick up a new set for now on...
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
Bryan F
Aug 18, 2015 02:28 PM
