Underdrive pullies??????
Old Feb 27, 2003 | 10:13 PM
IROCBandit's Avatar
Well i'm starting to wonder what has been done to my car before i bought it. ive had to replace the belt twice and both times when they look it up in the computer the belt they give me is too big, so i just get the number off the old belt. also my alternator doesn't charge as much as it should(not sure of the voltage meter either). do you think i already have underdrive pullies??
Old Feb 28, 2003 | 09:35 AM
Vader's Avatar
Bandit,
By "too big" I'm presuming you mean too long. How much longer is it than you need? If it is only an inch or two, you may have an uunderdrive sheave onthe crank, or an aftermarket replacement part, like a PS pump with the wrong sheave diameter or a tensioner with the wrong idler size. If the belt is several inches too long, you may have a removed component and rerouted belt.
Old Feb 28, 2003 | 12:41 PM
IROCBandit's Avatar
ya meant to say too long, sorry about that. its only about 1 inch too long if that helps
Old Feb 28, 2003 | 01:30 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Measure the diameter of your crank pulley. I dont know what it should be off the top of my head, but if you post the diameter of the crank pulley, someone will be able to go out to their car and verify. No point in you, i or anyone else guessing, it's as easy to check as that.
grngryoutmyway
Oct 18, 2016 05:48 PM
bigjay89gta
Oct 15, 2015 08:04 AM
bryaniskoo
Oct 1, 2015 03:18 PM
italiano67
Sep 22, 2015 08:42 AM
Navy8125
Aug 22, 2015 07:13 PM
