changing the firing order
Old Feb 28, 2003 | 12:51 PM
sllt1776's Avatar
Car: 89 Iroc-Z
i have been reading that you can change the firing order. i want to try the firing order from the ls1. i read that the crank configuration is the same, but are the camshaft lobes in the same spot. just wondering if anyone has tried/read about this change?
Old Feb 28, 2003 | 01:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No the cam is different; the combination of where the pistons are, and what the valves are doing in relation to the pistons, is what determines the firing order.
Look at the order 18436572; without changing the crank, the only thing you can do is to swap 2 cyls that are 4 positions apart in the order. e.g. you could exchange #4 & #7 by grinding the cam differently and putting the wires in the dist in the correct order (18736542)
Old Feb 28, 2003 | 02:07 PM
sllt1776's Avatar
Car: 89 Iroc-Z
yea chevyhipo talks about it and says the ls1 is 18726543 and ours is 18436572 they change the 72 with the 43. i figured it would require a cam change but they make no statement about it.
Old Mar 1, 2003 | 11:03 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Why would you change the firing order? Is there any gain from doing that?
Old Mar 1, 2003 | 11:29 PM
rsscoty's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: auto
according to chevy hipo yes there is a gain to be had. There is a slight gain to be had and a vibration reduction. It doesn't really give specifics though
Old Mar 2, 2003 | 07:06 AM
ede's Avatar
ede
cross fire has always been a problem on SBCs between 5 and 7, maybe that's part of it.
Old Mar 2, 2003 | 08:21 AM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
If you change the firing order, you still have that problem, you just move it from cylinders 5 and 7 to cylinders 1 and 3. I would think all you really get from that is having to buy a custom ground cam
Old Mar 3, 2003 | 10:59 AM
Jza's Avatar
Jza
Probably get a different engine note [a unique sound], as well.
Old Mar 3, 2003 | 12:28 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
If you're running a dual plane intake, you'll never see a difference. Same with the 1-3 change that black89ws6 pointed out. If you're running a single plane, the only gains you'll see are above 5500 RPM.
Pros have tried it multiple times, and the HP/$$ ratio just isn't worth it.
eightsixseven
Dec 16, 2024 01:50 PM
1992Vortec
Aug 31, 2015 08:05 PM
86IROC112
Aug 21, 2015 07:20 PM
TheExaminer
Aug 19, 2015 10:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
