Jacobs ignition installed
Old Mar 2, 2003 | 07:11 PM
82camaro's Avatar
Car: 82 camaro SC
Well, the Jacobs ignition is installed. Along with a Jacobs cap, wires, and AC plugs.
Before I started it was running OK. First we put in on the Snap-on 'machine' and the ignition was working good.
Installed the plugs first, and drove it. No change. Opened up the gap a little bit and it idled rough. Opened up the gap to 60 and installed the Jacobs stuff. The first thing I notice is how quick it starts. It idles smoother, can hardly tell it has much of a cam. Throttle response is improved greatly. The 4500-5000 rpm wall seems to be gone. It will rev to 6000rpm+ without a problem. It seems to run stronger as well. I'm impressed.
With a stock engine, the stock HEI is probably plenty good. However, if you have done some engine mods, an aftermarket system might be a good idea. FYI, I got the system for 40 bucks used--800 miles on the system and totaled the truck.
Old Mar 2, 2003 | 08:30 PM
WaynesRS's Avatar
I've been wondering about there ignition stuff . If its as good as it claims in the magazine ads . Of course my car would prabably not benefit much on it . But I've been curious about the real benefts for a V8er ...Glad to hear your satisfied .
Old Mar 3, 2003 | 12:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Which system is it? I got the Omnipac in the '97-timeframe, thought it helped a little but couldn't point to any particular quantitative performance improvement. I was using a converted points distributor for the trigger.
I took it off the '57 last year in favor of the HEI/Crane HI-6. I was trying to solve an intermittent high RPM cut-out problem. I think I've found it now - valve springs.
Old Mar 3, 2003 | 01:19 PM
82camaro's Avatar
Car: 82 camaro SC
"suppposed" be a little better than the omni-pac. It's the Omni-Magnum. I forgot to add the mileage increase. So far, with 150 miles on it I can see the mileage increase is going to be substantial. If I can get it up over 20mpg, I'd be happy since my daily driver(91 jimmy) gets around 22.
Old Mar 3, 2003 | 03:04 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
I've heard alot of good things about the Crane HI-6. Anyone else have this or heard of it?? I know its digital instead of the outdated solid state analog technology, but as far as quality and how it compares to jacobs, MSD, Mallory and the like?
Caspar
Jun 19, 2016 11:19 PM
theurge
Aug 21, 2015 12:46 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
