Are these injectors worth rebuilding?
Old Mar 5, 2003 | 11:00 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
They're the stock injectors that came with an '88 Camaro SC (2.8L V6 MPFI) with ~130K miles.
Basically, I'm trying to smooth out my idle quality (it's pretty rough at a ~775 RPM idle), and I know the injectors can stand to be cleaned. Also, only 4 of the injectors are original; 2 of them are new Bosch injectors that I got a little over a year ago.
I would just send them to Cruzin' Performance, except that I remember the last time I tried to do that with the injectors out of my '89 IROC, I was told that they weren't worth rebuilding (b/c they were Multitecs in that year). I have no idea what GM was using in '88 on their V6 cars, so I just thought I'd check here to see if they're worth rebuilding or not.
Old Mar 6, 2003 | 10:05 AM
Vader's Avatar
Sancho,
IIRC, the Multecs didn't arrive until 1989. Your '88 may still have Bosch injectors. If the injectors are rounded at the upper and lower ends, they are probably Multecs. If they are stepped or squared at the ends, they are probably Bosch or Rochester, and worth sending in.
Magman
Sep 13, 2015 08:43 AM
ramicio
Sep 6, 2015 11:25 AM
hayesaw0210
Aug 23, 2015 11:15 PM
djmarch
Aug 10, 2015 08:42 AM
hokis
Aug 9, 2015 03:57 PM
