Bad fuel filter right out of the box?
Old Mar 10, 2003 | 09:16 PM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
Hey guys, Maybe someone can help me figure this out: I just finished replacing my in tank fuel pump and started engine up - ran fine. Then I remembered to install the new fuel filter, but now it only tries to start and dies as soon as I stop cranking it.
Has anyone had a brand new fuel filter that wouldn't pass fuel? It's a Fram filter, the correct part for the car, and nothing seemed out of the ordinary when I installed it. Any ideas? Thanks in advance:hail:
Old Mar 10, 2003 | 09:34 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Did you install it in the right direction??
Old Mar 10, 2003 | 09:36 PM
LastViceRS's Avatar
Car: '91 RS
Yes, I checked it twice, but you're thinking.
Old Mar 10, 2003 | 09:56 PM
Vader's Avatar
I was going to ask if it was a Fram filter...
Does the fuel pump run for two seconds as soon as the ignition is turned ON?
Old Mar 10, 2003 | 10:05 PM
383 rocket bird's Avatar
I would try a different filter. If it's not the problem than you alredy have one for your next tune up and there is no problem.
Old Mar 10, 2003 | 10:31 PM
LastViceRS's Avatar
Car: '91 RS
Vader, Yes - the pump does run for two seconds when I turn the key on, so I don't think it's the pump. Oh yeah, I did also notice that at the same time as I installed the filter , the fuel tank no longer releases pressure when I loosen the cap.
383 rocket bird, Yeah I think I'm just going to get a new filter (NOT Fram) tomorrow and try that. Just seems like too much changed after the new filter went in.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
