Best way to deal with a rear main leak without changing the gasket?
Old Mar 11, 2003 | 09:19 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
I just put synthetic oil in my car today and now there's a rear main leak, pretty bad. This motor only has 8k on it and when I put it in, I didn't have any way of turning the motor upside down so I could install the oil pan gasket. result= one leaky SOB. I cleaned it as best I could and then put gobs of RTV on it and it sealed up pretty good. It doesn't leak when the car is NOT running, only when I run it...and it's making my clutch slip. If I run it hard...the the torque seems to tweak the rubber gasket or something and make it leak.
What should I do? I bought the most Oil resistant sealant I could find ( Ulta Blue Permatex) and I am going to clean it with brake cleaner and try to get a clean seal. i am going to jack up the raer of the car so that the oil is sent forward, to get the spot as clean as possible. Then let it dry for a few hours.
I also have a new poly trans mount that I think should help a bit with the torquing prob. The car has motor mounts that are only 10k old.
Any other Ideas? Is there any special sealant just for this problem?
Old Mar 11, 2003 | 09:52 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Did a search....
I did a search and there are guys who said that they could change thier rear main seal on thier lunch hour.
I have a 5 speed car. If I try to change the seal....whcih is definately leaking do I have to unbolt the bell housing and slide the trans back?? What if the seal is laking where the rubber meets the gasket???
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
MY87LT
Aug 17, 2015 08:43 AM
mizz0313
Aug 12, 2015 06:45 AM
