steering wheel
Old Mar 11, 2003 | 11:21 PM
gm hombre's Avatar
Car: 1989 WS6 GTA
steering wheel
this is my problem, i have a 89 gta with radio controled steering wheel,it seems my steering is kind of loose and there is a bolt not properly screwed in right, what i want to know is how do i get the plastic covers off after i have removed the steering wheel, so i can get to the bolt and screw it in right. if someone has a diagram it would be helpful,thanks, gm hombre.
Old Mar 13, 2003 | 09:37 AM
Vader's Avatar
Hombre,
It sounds like your tilt mechanism is loose in the lower bowl of the column. Search the archives for Loose Tilt Wheel and see what you discover. You should be able to find threads with complete instructions.
Old Mar 13, 2003 | 08:23 PM
gm hombre's Avatar
Car: 1989 WS6 GTA
vader you are right,when i tilt the steering i can see the loose bolt,i got the bolt in but i have to tighten good so it doesn't come loose again,i'll check archives,thanks again vader.
Old Mar 13, 2003 | 10:29 PM
Vader's Avatar
Instead of just tightening them, remove them one at a time, apply some thread locking compound (like Loctite 242) and install it. Move on to the next one until all four are done.
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
