How the hell do I fix these plug wires?!
Old Mar 13, 2003 | 01:22 AM
StaticFX2000's Avatar
Today I bought a set of Accel Super Sport 8mm wires for my 84 2.8. Well, some dumbass thought it would be nice if I had to cut and crimp the distributor end myself, my problem is...I can't figure out exactly what i've gotta do. It's hard as hell to get the wires through the boot, much less be able to put a connector on there and pull it back IN to the boot.
Anybody wanna help me out here?
Old Mar 13, 2003 | 02:09 AM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
or you could just return them and get a set of wires that are pre cut for your specific car
Old Mar 13, 2003 | 05:14 AM
ctandc's Avatar
Put the wire without the metal terminal through the boot......THEN crimp the terminal on, then pull the wire back through the boot until the terminal is inside the boot. Do yourself a favor, get some silicine spray, it helps lube the wire / boot and makes it much easier to work with.
HTH
Old Mar 13, 2003 | 05:36 AM
ede's Avatar
ede
i crimp the ends on first the use a screw driver on the end of the terminal to push it thru the boot, after it's in enough to grap with needle nose plires i pull it out with the plires.
Old Mar 13, 2003 | 05:44 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A little dielectric grease (that clear silicone kind) on the ends of the wires makes it much easier.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
djmarch
Aug 19, 2015 12:07 PM
