possible head gasket failure
Old Mar 13, 2003 | 08:38 AM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
ok, i was looking at my motor today to see if there was any milky white stuff anywhere i can see.... the intake is of so this helped big time... as i went on i looked at the no4 int valve and it had a cruddy looking stuff on it......... t wasn't thick, and it looked like maybe a coolant seeping past the gasket into the combustion chamber, but there are no signs of a mix going on so far.... the oil was changed to get the gas out from running a stock chip on a 30lb inj engine.......
when he drained it, it was like thin as hell but smelt like gas....... so i just don't know.......
does anyone have a pic of a valve that had coolant contamination on it???
thanks everyone
Old Mar 13, 2003 | 08:45 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A bad head gasket cannot possibly cause buildup of anything on the intake valve. There's no path that leads that way.
Coolant doesn't build up a residue on intake valves. It does the opposite: it literally steam-cleans things. You can spot coolant leaks in the induction and cylinders of an engine by looking for clean places.
Most likely, it's fuel residue.
Cornholio7979
Sep 20, 2018 02:31 AM
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
