my car has been sitting for 6 months
Old Mar 13, 2003 | 06:07 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
hey every oen i had a ? my car has been sittign for 6 months and is now winterized i wanted to start it up because i herd some ware that it is good to start the engine up every now and then. is this true or shoud i leave it till spring?
if i do go to start it is there anything special that i should do before i start it so i dont ruin the engine other then make shure all the fluids are topped off?
thanx alot in advance
Old Mar 13, 2003 | 06:17 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
THe best thing you could do for it before starting after a while is put in new oil and then prime the engine for a few minutes to get some oil up where it has not been for a while. Pull the distributor and you can use a 1/2 or 3/8 electric drill with a oil pump priming tool. Basically, the same way you would do it if the engine was brand new. If you are only going to start it because you think you should, you may just want to wait until spring. I assume you store your car for winter. Do you go through a storage procedure? If not you should start.
Old Mar 13, 2003 | 07:02 PM
z28monster's Avatar
Car: 86 IROC-Z
yeah its all winterized
yes i do its all winterized right now . moth ***** batterie is out of it thats all i know of and all the fluids are topped off.
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 26, 2015 04:59 PM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
L98GTA87
Aug 5, 2015 11:02 PM
