Speedometer Problem
Speedometer Problem
On my 92 Camaro 3.1 V6, I'm experiencing an intermittent speedo problem. When it is cold outside, the speedo does not work or works erratically. Warm temperatures & when the car is warm, the speedo works OK. At least this is what my son reports. ( I haven't driven the car to see what is actually happening.) Can anyone offer some possibilities to check out? Also, would this car have an electronic or mechanical speedometer. It is an analog gauge.
Thanks, FJK
Thanks, FJK
Car: check
Engine: check
Transmission: check
Re: Speedometer Problem
Thanks, FJK
Thanks, FJK
Observing the functionality of the cruise control and/or a scan tool on the ECM can help narrow down which component/wire may be causing the problem.
RBob.
GeneralIesrussi
Sep 3, 2015 03:23 AM
