What with Stock Vortec heads to get low 12s in the quarter mile
Old Mar 15, 2003 | 03:31 PM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
350 2 pc rear main stock bottom end, 3.73 posi and 5 speed....
i was thinking
hooker long tubes, custom y pipe, any catback, Msd 6al, blaster 3 coil and 8.5 wires, holley 4150 750 DP carb with a holley blue pump and any AFPR, Performer RPM air gap intake manifold with an XE284 cam and lifters package, have the heads machined for screw in studs and guideplates, use a metal shim for a head gasket and run comp rockers, comp timing chain....any input would be greatly appreciated...
thx
-mark
setup is for another car....iroc-z
Old Apr 5, 2003 | 12:27 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Look at my signature. I ran 12.36@110 with zero traction on 100 hp shot.
Old Apr 5, 2003 | 01:05 PM
Purple Monkey's Avatar
Car: 1990 Eagle Talon TSi AWD
Engine: 4G63T
Transmission: 5 speed
how much lift can those heads take without machining, someone told me .420"
Old Apr 5, 2003 | 10:22 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I think it's .450. I did use the valve springs that are matched to my cam. Not the stock springs. More than likely if you are wanting low 12's they will have to be machined.
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Old Apr 6, 2003 | 05:55 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
kfoley says...and I quote...."The Xtreme Energy cams are a great line of cams. The most popular setup is a 355 with Vortec heads, Performer RPM intake manifold and a XE274 cam. You can knock down low 12's with this combo when tuned correctly. It's also an inexspensive build too and puts out a little over 400 hp and 420 tq.
Old Apr 6, 2003 | 05:27 PM
ShaneBuss2's Avatar
Car: 1992 Firebird Coupe
Engine: 357ci Carb
Axle/Gears: 3.73 posi, stock rear
you can do it.. stock vortec heads?
you just need a jato rocket
Old Apr 6, 2003 | 07:10 PM
Tailmaphas's Avatar
Car: 87 Pontiac Trans Am GTA
Engine: tpi 355
Transmission: t56 6 speed manual
Axle/Gears: 9 bolt 3.90
Hey, 94-6spd, do you have an e.t. for the 83 w/out the spray-just on the motor? I am building 355 vortec head setup with perf rpm intake, comp 292 magnum cam, 1.6 rr, 750 dp, 15/8 header, ypipe, flowmaster, no cat, flat top pistons, holley blue pump, 700r4 w/ super transkit, stock susp now(future plans spohn Torque arm and lca's) w/ 275/60/15, 4.56 posi. Not sue what will run when done. Trying to compare similar setup to estimate.
Old Apr 6, 2003 | 08:19 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
https://www.thirdgen.org/techbb2/sho...hreadid=165669
Look at Ponykiller. he's got relatively stock vortec heads with the xe274 and an rpm intake, using 3.73's as well... he's knocking down low 12's all day long.
Eric
Old Apr 6, 2003 | 09:36 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
When my vortecs were stock, I measured them to take about .490" safely
Old Apr 7, 2003 | 11:17 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I don't have a time just on motor yet but I am planning a trip to the track either this weekend or next weekend. Have you thought about putting a single plane on it with that 292 cam? It would probably help your times a little.
Old Apr 7, 2003 | 07:01 PM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
You gotta be ****t'n me, you pulled a 1.6 60 ft and you call that ZERO traction???!?? Wow. Usually cars that pull 60's fts much quicker than that pull wheelies
Old Apr 7, 2003 | 07:03 PM
Car: Junk
Re: What with Stock Vortec heads to get low 12s in the quarter mile
i was thinking
thx
-mark
check out the specs for my firebird, before I blew the motor thats exactly the setup I had, and it ran dead even with a friends firebird that ran 12.40's @110. My new motor should be good for 11's, but of course that with canfield heads and a solid cam
Old Apr 7, 2003 | 09:26 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
No, Actually the day I ran 12.36 @ 110 my 60' times were 1.97's and 2.0's. That in my opinion isn't very good with a brand new set of MT et drag slicks. I was spinning the slicks all the way through first gear and was going sideways. The next time I went to the track I decided to put the lca's in the stock location instead of using the spohn relocation brackets. When I did this my 60' times dropped dramatically. I wasn't impressed with the relocation brackets at all. The rest of the track times were at 1/8 mile tracks.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
