replacing rear main seal
Old Mar 17, 2003 | 01:40 PM
91Z28-350's Avatar
Can anyone give me some tips on replacing the rear main seal on an L98 (one piece)? I haven't checked my service manual yet, but the manual isn't exactly the best in terms of tips. How do you pull out the seal? Is there any sealer that needs to be added after the new seal is installed?
I'm putting in a new tranny, so I figured I'd might as well replace the seal once it's down.
Thanks!
Old Mar 17, 2003 | 03:08 PM
ede's Avatar
ede
pretty easy, unbolt the little houseing drive out the old seal drive in the new. i use sealer on the OD of the seal and assembly lube on the ID. then bolt the seal houseing back to the block.
Old Mar 17, 2003 | 09:31 PM
long&low's Avatar
Car: 88 ext.longbed 1/2 ton
Engine: TPI 350
Transmission: Slushbox 400
So on the L-98s do you have bolts that go thru the pan and into the seal housing? Or do you have the studs in the housing that you guys are removing?
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
Reborn756
Sep 4, 2015 03:42 AM
Exxon Limited
Aug 9, 2015 08:13 PM
Leggman1
Aug 6, 2015 04:15 AM
