What do you guys think ?
Old Mar 17, 2003 | 04:41 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I did some of my head bolts the ones under the valve cover with teflon paste sealer. Then I ran out, had to get more. I had only partially tightened them up. Got some more sealant two days later and did the rest on the outside. Then I tightened them all up.
Do you think that I will run into a problem with the inner head bolts leaking because the sealent might have hardened up before I did the final torque?
Should I pull them and re do it?
What do you think?
Old Mar 17, 2003 | 07:24 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
ttt
Old Mar 17, 2003 | 07:45 PM
Vader's Avatar
If you used an anaerobic sealant, such as Loctite or Permatex PST, the sealant will not harden completely until it is in the absence of any air, such as when the cooling system is filled or oil can seal the compound from air.
It's a tough call. I would bet you'll get an adequate seal, since the compound never really completely hardens. It remains flexible to maintain a seal under heat/cool cycles and other expansion or minor motion If you used some other type of sealant, I have no idea what your results might be.
Old Mar 17, 2003 | 09:13 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Thanks Vader for your feed back, it was the Peremetex pst.
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
