Hurst line lock
Old Mar 18, 2003 | 08:12 PM
Alan84TA's Avatar
Hurst line lock
How does the hurst line lock work? Do you press the button once to activate and a second time to deactivate or do you have to hold the button and when you release it deactivates?
Old Mar 18, 2003 | 08:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
All line locks work the same.
You can install 2 line locks for the front and rear but the most common installation is for the front brakes only.
You step on the brake. Push the line lock button and release the brake. As long as the button is held (a momentary button), the line lock holds the brake pressure for the front brakes and the rear brakes are released. You do this to do a burnout so that the rear brakes aren't dragging. It's easy to heat up the rear brakes and get brake fade.
Once you're almost done the burnout, you release the line lock. The pressure is released and the front brakes release allowing you to roll out of the water box.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
snakeshooter
Sep 7, 2015 11:13 AM
TBRays98
Sep 6, 2015 05:05 PM
