R12 &R134a Gauges
Ede,
The manifold and hoses are functionally the same. The differences are in the connectors and the handy little pressure/temperature graduations on the face of the gauges. Instead of new hoses, you might be able to find adapter fittings to use your current R-12 hoses and manifold. Many "new" gauge manifolds still come with ¼" SAE flares (with 7/16-20 threads, just like your old gauge set) and still need the ½" Acme thread adapter for automotive low-side charge ports.
You can purchase these adapters almost anywhere, and for a lot less than a new manifold. Here are some on-line possibilities:
http://www.heco.net/AC_Tools.htm (Reasonable prices)
http://whiteac.com/retrofit.html
http://www.rparts.com/Catalog/Tools_...gauge_sets.asp
As for the P/T charts, which ones do you want? I can scan them if you need them.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I bought the adaptor fittings from SnapOn to use my R12 guages and hoses on a R134a system. I havn't seen an R12 system in years now so there was no sense in letting my old guages gather dust.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
How much does a good gauge set cost these days? All the fittings on my old R4 gauges leak.
