comp xe cams
Old Mar 19, 2003 | 08:42 PM
LYV18F's Avatar
comp xe cams
anybody have the comp xe 262h or 268h? any feedback? i was thinking about using either one of those or the lt4 hotcam with hsr and tfs aluminum heads. right now i'm thinking the hotcam would be a better choice...
also, i was under the impression that the xe cams had a 112 lsa, but on comps website, i saw that it was 110... anybody know?
thanks
edit: hopefully, i'll be getting all these parts this summer, depending on the job i get. so i've got time to consider exactly what parts i want.
Old Mar 19, 2003 | 09:47 PM
gruveb's Avatar
Car: 1989 IROC-1
I have a 262 in my 305 and I'm very pleased with it.
I do believe they are 112 LSA though.
What engine are you going to throw the cam in?
Old Mar 19, 2003 | 09:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's a few different ones with different lobe separation. I have a XR264HR-12 in my 305, which is on 112° lobe sep. I had a XE274 and a XR282HR in my 400, both of which were 110°. The 262 specifically is available in 3 lobe seps IIRC: 110°, 112°, & 114° for different applications.
The LT4 HOT cam is a really weenie little thing. If you're going to all that trouble and expense, you can do alot better.
A little more info about the engine and car would be really helpful.... cubes, compression, gear, converter, what you intend to use it for, etc.
Old Mar 19, 2003 | 11:01 PM
LYV18F's Avatar
right now my car is entirely stock.
what i plan on doing is getting the engine pulled and completely checked out, bored 30 over and checked to make sure the block is ok (it's an L98 btw). then i plan on putting in the hsr, trick flow heads (not sure exactly which ones right now, most likely 64cc), obviously headers/full exhaust, don't want the compression too high, definitely want to use 93 octane. not sure about the converter right now.
what i want is for the car to look and sound stock (at least at idle). i know the hotcam is pretty weenie, but i don't want something that will make the idle sound like a metal garbage can rolling down the street. it will probably see some track use.
i just want something that will be respectively fast and can whoop some *** on the street every once in a while. by the time i get all this stuff, it will not be daily driven, and will not need to be emissions legal (hence the hsr). it's not gonna be a full out race car, just something to drive every once in a while to have a little fun in.
thanks for the replies
it's good to know you've got some choice as far as the lsa goes
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
sandman92084
Sep 12, 2015 10:27 PM
Strick1
Sep 4, 2015 07:11 AM
