car not running right?
Old Mar 20, 2003 | 12:40 AM
RSstocker's Avatar
hey guys, i have a 91 RS with a new 305, auto, and i think i might have a problem. my car runs great and everything but i feel like i have no bottom end power at all, like less than a civic, my mods are just 3" exhaust and flow. muffler and should my car be able to spin the tire? i have cooper cobra 245's and i cant even chirp the tires... ever which leads me to believe that my car isnt tuned right, what should i adjust or check, to fix my problem, or is there no problem
please help!!
Jeremy
Old Mar 20, 2003 | 12:53 AM
kingrobert's Avatar
just becuase you can't chirp the tires with a 305 auto doesn't mean it isn't tuned right, how does your get up and go feel when you put the pedal to the medal
Old Mar 20, 2003 | 09:19 AM
RSstocker's Avatar
off the line it feels very weak, more weak than with the 150,000 mile engine. my engine now has 1,400 miles on it, once i am actually going at about 20, it is a lot quicker. does my engine just need more break in time?
Old Mar 20, 2003 | 09:22 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What cam is in it?
That's usually the thing that makes the biggest difference. Using a cam that provides more top-end power usually costs some low-end grunt.
You have 2.73 gears; even the slightest decrease in that low end is going to be very noticeable, because the motor spends so much of its time just off idle.
Try a looser torque converter.
Old Mar 20, 2003 | 09:25 AM
RSstocker's Avatar
it has the stock cam, everything is stock except the little exhaust work.
Old Mar 20, 2003 | 09:39 AM
Slade1's Avatar
Even with my 2.73 gears I was able to chirp my tires in 1st and 2nd. It also lead to the untimely demise of my 2.73 gears as they pretty much grenaded on me. I now run 3.23 gears.
There are quite a few 305 TBI's that have ***** for some reason... despite the fact GM tried cutting them off on most of them...
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
