engine hummer
Old Mar 20, 2003 | 08:28 PM
CrazedCamaro's Avatar
Car: 1989 RS Camaro
Engine: 305 POS
engine hummer
Okay my car makes this really weird humming noise from when i hit 40 mph only until i get to 60 mph. Before 40 its fine and after 60 its fine. Help! I dont know why it is doing this. Should I be worried or should I just add it to the list of things to be done. Let me know what you think I should do.
Old Mar 20, 2003 | 10:24 PM
Vader's Avatar
Try those same speeds in a different gear. That can help you determine if the noise is from the engine, transmission, or rear axle or other driveline parts.
Old Mar 20, 2003 | 10:29 PM
Car: 1989 RS Camaro
Engine: 305 POS
I have tried it in different gears and it always does the same thing. I really shouldnt say always, but occasionally. like somdays it does it in all gears and somedays it doesnt do it all in any gears... I dont know Im lost on this one
Old Mar 21, 2003 | 07:38 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like maybe a drive shaft issue, like a bad U-joint, or a loose pinion nut, or a worn extension housing bushing in the trans... if it still does it when you take it out of gear and coast, it can't very well be the engine.
Old Mar 21, 2003 | 09:38 AM
Jim L. Saylor's Avatar
Car: 1983 z/28 t-top
Engine: 305 Carb LG4
Transmission: 5 speed
It's not a BUZZing sound. is it? That choke relay bugs ya sometime when the ground is bad...
I replaced 2 before I found that out.
just my .02
Jim
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
