What do u think this setup has for power?
Old Mar 20, 2003 | 08:35 PM
drumike102's Avatar
-LT1 intake
-Mild ported heads
-LT1 cam
-Hooker Super Comp Headers
-3" Hooker Super Comp Cat-Back
-Race Rebuilt TH700R4 with Shift kit
-2,800RPM Torque Converter
-3.73 Richmond gears
-Auburn posi differential
-Accell 8mm racing wires
-Accell AFPR
-Custom made Ram-Air (thanks to Andris Skulte)
-MAF screens removed
-Dropped <A/C, A.I.R, Cruise, Cat, and EGR>
-TB coolant bypass
-Hurst Dual-Gate Shifter
-SLP Air Foil
-K&N filters
-Holley performance fuel pump
-Spohn Subframe Connectors
-Re-located Spohn Lower Control arms
-Nordskog Air/Fuel Gauge
-ARP manifold bolts
All this on a L98 Iroc
What do u think?
Old Mar 20, 2003 | 09:40 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Get a better cam then the LT1 cam, it is a very tiny grind. Something along the line of a COMP XR270HR grind for factory hydraulic roller block.
Old Mar 21, 2003 | 09:15 AM
drumike102's Avatar
can you give me an idea of what u think that setup would be putting out for hp?
Old Mar 21, 2003 | 09:33 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Depends on the heads.....
Nothing else in that list is any better than a stock LT1. L98 heads will not flow as well as LT1 heads. You won't have as much compression as a stock LT1.
Somewhat less than a LT1 would with the same headers. At its absolute best it would equal a LT1, which is highly unlikely.
Put a better cam in it. It's a brick-wall handicap, as all the LT1 people are well aware. The stock LT1 cam is so weenie you can drop it into an otherwise unmodified TBI 305 and it will run with the stock fuel and spark curves.
All in all, it's a whole lot of bucks and very little bang. Not how I would spend all that money, for sure.
Old Mar 21, 2003 | 09:52 AM
drumike102's Avatar
do you think with that setup i would be able to run 13's in the quarter?
Old Mar 21, 2003 | 04:06 PM
drumike102's Avatar
ttt
Old Mar 21, 2003 | 04:31 PM
84zeddd's Avatar
I would think 13.7-13.9 at 97-99mph.
stalkier
Dec 6, 2015 11:25 PM
gta90
Sep 15, 2015 04:00 PM
L98GTA87
Aug 25, 2015 02:23 PM
sailtexas186548
Aug 24, 2015 10:11 PM
86White_T/A305
Aug 17, 2015 12:16 AM
