Loud knock
Old Mar 23, 2003 | 04:24 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
Loud knock
Just firing my engine up....for the first couple times here....now...when the engine wants to stall (cold outside)...its starts knocking EXTREMELY LOUD!!!... but it only does this ..when its about to stall...i mean like 200RPM....it sounds like someone hamering on the black.............I dont know where my timing stands...I just lines up the rotor w/the #6 pin..............and after the cam install...and left it there...
Rob...
Old Mar 23, 2003 | 10:09 PM
87z28camaro's Avatar
Car: 1987 Z28 Camaro
Engine: 305 tpi
iit could possibly be your exhaust, or are you for sure its in your engine/
Old Mar 24, 2003 | 03:58 PM
Car: 1983 Z28 Clone
Transmission: TH350
I do have an exhaust leak at the donut...but.. jeeezz.. it sounds like metal to metal....
Old Mar 24, 2003 | 10:54 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Piston slap maybe? That sometimes happens when engines are started in really cold weather.
Old Mar 25, 2003 | 11:05 PM
305LG4Cutlass's Avatar
It could be exhaust. I had a sound like this in my cat converter and the only way i knew it wasn't a rod knock was when i revved it up it turned into completely different noise that definately wasn't a bottom end noise.
It's not knocking any other time and oil pressure is good?
Old Mar 26, 2003 | 10:00 AM
Engine: 305 tpi
it could also be one of many other things wich are, a knock of course, or.... your transmission mount, engine mount, exhaust, as in my care, i heard a loud medal to medal knock when i'd let it idle, but i came to find out that my tranymission mount was sooo loose, so i tightened it up, and it was gone,
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
loud91rs
Oct 5, 2015 10:05 PM
efiguy
Sep 27, 2015 01:30 PM
tgp1990
Sep 4, 2015 06:24 AM
