Vehicle will not start
Old Mar 23, 2003 | 04:47 PM
JCherwien's Avatar
Car: 1984 Autoform Firebird
Engine: 2.8l V6
OK...So I'm having some issues with my 84' bird...
Recently when it's nice out, and somewhat warm
and sunny, after I've driven the vehicle for a while,
then parked it, it will not start again...The car turns over,
and will sometimes catch, but then it dies right away...
I just had the starter replace, so I know that's not the
issue.
Normally when this happens, I just have to let it sit
for 3-4 hours, then it starts again...
Any ideas?
Old Mar 23, 2003 | 05:10 PM
Morley's Avatar
Injectors or ignition system getting high impedance induced from the heat.
Old Mar 23, 2003 | 05:12 PM
JCherwien's Avatar
Engine: 2.8l V6
Don't think it would be injectors...it's carb'd....
As for the ignition system, would that just have to
be replaced or is there a way to fix it?
Old Mar 23, 2003 | 06:13 PM
Morley's Avatar
could be the fuel soilnoid in the carb if it is the computer controlled kind. As far as the ignition, it could be any part of the system, wires, pickup coil, reluctor, primary coil, ignition module. You'd need to figure out which piece is causing the problem and change it. Unfortunately with heat induced problems it is almost impossible to bench test parts and find the problem. Start with the cheapest/easiest parts and change them 1 at a time until you have it fixed or eliminated all of the pieces.
Old Mar 25, 2003 | 01:51 PM
johnnyformula's Avatar
i have a similar problem, but mine never catches. the solution? the starter is so close to the engine it gets hot & won't work properly. i believe summit racing sells an inexpensive heat shield for the starter that's supposed to fix this...
just an idea
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
g.l.mos
Aug 22, 2015 12:02 AM
GVMV
Aug 16, 2015 08:01 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
