Turn over engine by hand?
Old Mar 23, 2003 | 06:38 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
I have an 83 Z28, LG4. It hasn't been started for about 4 years. My plan is to remove all the spark plugs (no compression) and spray some "oil fog" into each spark plug holes and then turn over the engine by hand. Can I do this by putting a socket wrench on the front of the drive shaft (Harmonic Balancer?)? Thought this would get everything freed up.
thanks,
phil
Old Mar 23, 2003 | 06:41 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
That should work, just make sure that the belts are off so it'll be easier to spin. I have a 396 big block that I turned by hand with a wrench on the harmonic balancer. If you can get the oil pan off, it probably wouldn't hurt to spray some stuff (WD40, maybe?) up inside the bearings if it won't budge. I had to do that on the 396.
Old Mar 23, 2003 | 07:13 PM
ede's Avatar
ede
if it's stuck or there is much resistance using a socket on the crank is a good way to break the crank bolt, if it turns easy then no problem. you might want to consider a flywheel turning tool, less chance of breaking the crank bolt.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
BrianI
Aug 9, 2015 11:52 AM
