power changes from day to day
Old Mar 23, 2003 | 07:27 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
from day to day my power will be different, some days it fells like it runs stronger than others without changing anything. one day it was so good that it would push you into the seat when you punched the gas at 50mph and fishtail when you accelerate from a stop. today it wouldn't even spin the tires and felt like it didn't want to go like it should. i did put headers on since the one real good day and the guy that did the y pipe put a 2" after the y(i'm going to take it back and have a new, better one made by a shop that builds race cars) and it seams weaker than having manifolds with a stock y with a 2.5" after the y. it would make sence being weaker now because it is pushing exhaust from 8 1 5/8" pipes into one 2" but would it make that much of a difference?
Old Mar 23, 2003 | 07:33 PM
CrispyClutch's Avatar
vacuum leak?
Old Mar 23, 2003 | 07:54 PM
TheViper's Avatar
Car: '84 Z28
i don't think so, it idles good. the engine is pretty new, it has a new carb and intake and has only the vacume lines for the pcv, vacume advance, brakes, and heat/ac vents. it is completely non computer controled. it is still a posibility but i think it would affect the idle quality more if it was big enough the hurt the power a lot.
Old Mar 23, 2003 | 07:58 PM
Possibly a gasket leak somewere then.
Old Mar 24, 2003 | 01:13 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
maybe your carb is just super moody, feed it more gas, they love it
seriously check the carb tuning though, and with headers your "break the tires loose torque" probably deminished a little in favor of upper end breathing, but it shouldnt be that significant
deracer
Apr 11, 2016 12:04 AM
gta90
Sep 15, 2015 04:00 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
86White_T/A305
Aug 17, 2015 12:16 AM
