Never heard of this before
Old Mar 23, 2003 | 08:58 PM
91RSmaro's Avatar
Alright, today I was driving my car. Got to where I was going, turn the key to the off position, took the key out... AND THE CAR WAS STILL RUNNING!!! I had no idea what to do, so I drove home. When I got home parked in front of my house, turned the key and the car shut off. If anyone has any idea, please let me know. Thanks alot for any help.
Old Mar 23, 2003 | 10:26 PM
Vader's Avatar
Since your engine is "stock" as you web page indicates, you likely have a faulty ignition switch or switch linkage. If you had a carbureted engine, I'd suspect dieseling.
Old Mar 23, 2003 | 10:27 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
were your floormats anywhre near the gas pedal...I did that before my gas pedal got stuck on the floormat and it dieseled after i shut it off, scared the hell out of me, then afterwards i felt like a jackass.
Old Mar 24, 2003 | 12:28 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Dieseled?
Like it turned into a two-stroke engine all of a sudden? I know this is not what you mean, so please explain I have never heard the term before and am curious.
Old Mar 24, 2003 | 02:05 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
dieseling= Eng continues to run when ign is shut off.
This happens if there's something within the combustion chamber hot enough to ignite the fuel/air mixture. Bits of glowing carbon build-up are usually to blame.
It can be very destructive since the 'ign' is not timed. It can ignite the fuel/air mixture too early (while piston is still coming up), putting excessive stress on the bottom end.
Crankshafts have been known to break due to dieseling.
Only happens to carb'ed engs since fuel inj cars shut off the fuel and ign when shutdown.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Jan 10, 2020 08:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mcbitchman
Sep 29, 2015 12:32 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
