Vibration
Vibration
I recently installed a new 350 HO crate engine with vortec head, SDPC's intake manifold, new injectors, motor mounts and transmission mount, in my 87 TPI GTA. Since then I have been experiencing mild vibration when the transmission is placed in drive. In Park or Neutral the engine idles very smooth. The vibration is only felt when a load is placed in the engine. I took the car to a transmission shop and they told me it's not the transmission or converter and to look for my problem in the engine compartment.
My base timing is set to 8 degrees (in drive) and I was wondering if advancing the timing might smooth out any vibrations felt?
Thanks,
Thanks,
Vader,
The GM engine I purchased was p/n 12486041 and it has a
one piece 4-bolt rear seal.
I used my stock 1987 5.7 Auto flexplate and I purchased a new
harmonic wheel balancer that was recommended for this engine
from GM.
The tranny 700R4 is the same and I used the same converter. My converter was replaced a couple years ago when I had this transmission rebuilt.
Let me know if you need any info. of if you have a answer to my vibration problem.
Thanks,
from GM.
Thanks,
Car: '89 GTA
Engine: ZZ6TPI
Does the vibration occur only while idling in gear, or while driving too? Also, does it vibrate when in park or neutral and raising the RPM's above idle?
No vibration is felt when the transmission is in either Park or Neutral, and raising the RPM above idle dosen't make any difference.
When you place your foot on the brake pedel and put the car in Drive, the vibration is felt at idle. While driving the car I can't really feel any vibration, but then I wonder if the higher RPM's dampen the vibration where it's not felt?
Transmission: 4L80E/4L80E
Re: Vibration
Car: '89 GTA
Engine: ZZ6TPI
Re: Re: Vibration
Originally posted by five7kid
How/why do you do that? I was under the impression you need to disconnect the brown ECM wire, and Drive or Park wouldn't make any difference (as long as you aren't reving the engine up).
roysatikas
Sep 22, 2015 08:15 PM
