Oxygen Sensor Head
Old Mar 24, 2003 | 11:54 AM
dp149's Avatar
Oxygen Sensor Head
Can somebody tell me what condition an oxygen sensor is in if the head is all white. Recently removed mine to check and the head was all white and no longer metal looking. Is this good or bad ? If it is bad, what caused the head to get all "white"
Old Mar 24, 2003 | 12:30 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Oxygen Sensor Head
A white powdery or flakey look is silicon poisoning. Is the sensor response also getting slow?
RBob.
Old Mar 24, 2003 | 12:37 PM
dp149's Avatar
I just changed it out and the car runs 100% better...Wasn't setting a code or light up the SES light just had not changed it and it was origianal (Car has 60K miles).
What would cause this poisoning ? Just normal usage or would that indicate another problem....
Old Mar 24, 2003 | 02:46 PM
Vader's Avatar
A whiteish ash coating can be normal if the combustion was clean. Bosch recommends changing the O² at 30,000 miles, so your's was probably due.
9192camaro
16
Feb 3, 2019 12:21 AM
bamaboy0323
Sep 3, 2015 06:07 AM
beast94
Aug 20, 2015 06:44 AM
