Code 44...
Old Mar 24, 2003 | 12:23 PM
CrispyClutch's Avatar
Code 44...
My car's been running really rough and crappy. I replaced the old, burned, rotten spark wires it had with some new accell 8mm yesterday.
Car runs only slightly better. I reset the ECM last night after doing the spark plugs, and after running for a while I got a check engine. Turns out to be a code 44, O2 sensor reports lean condition.
The guy at the parts store said that my old spark wires causing the car to run ****ty may have fouled up the O2 sensor with carbon causing it to report a fault, making my car run *** aweful. Would this make sense?
I replaced my O2 sensor only about a year ago... hmm... Could it be anything else?
Old Mar 24, 2003 | 04:41 PM
Vader's Avatar
I'd pull the O² and test it in a propane flame - or just replace it. If you don't have a lot of miles on the sensor in that year, you might just want to test it. Since it's been out recently and I KNOW you used anti seize compound, it should come right out with no problems.
Old Mar 24, 2003 | 04:49 PM
Yup you know it!
I just replaced it,MUCH better, but still kind of rough. Im going to pull a spark plug and see what shape my plugs are in, andthrow a bottle of octane booster in and blow out some carbon... Old O2 sensor was just covered in carbon!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
