how much does head work usually cost?
Old Mar 24, 2003 | 10:40 PM
19WS6T/A91's Avatar
i want to get my heads modified to accept an lt4 hotcam. can anyone give an approximation on how much this would cost?
thanks,
david
Old Mar 25, 2003 | 12:42 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
It should just involve replacing the springs, unless you have problems with the 1.6 rockers. I would just do it yourself, just borrow a valve spring compressor from you local parts shop.
Old Mar 25, 2003 | 10:25 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
what about having the guides cut down....... the hot cam has too much lift for stock heads.
Old Mar 25, 2003 | 02:15 PM
19WS6T/A91's Avatar
if i can do it myself i will, i just didnt know if anything else needed to be done besides changing the springs.
thanks,
david
Old Mar 25, 2003 | 08:32 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
thanks,
david
Be sure to port and polish the heads while they are off. That will make a world of difference when you have the LT4 cam in there. Good for at least 30 hp if done right. Follow link at the end of my sig.
midge54
Dec 27, 2019 04:14 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
jharrison5
Aug 19, 2015 05:53 PM
89mulletbird
Aug 12, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
