any ideas on this?
Old Mar 25, 2003 | 01:48 PM
IROCafros's Avatar
any ideas on this?
ok my car has never had any major problems but 2 days ago i was driving it around more then usual and i noticed that the engine was shaking and and sounding really bad, so i turned back home and oh a turn my friend said he heard a pop and my shut off and we just kept rolling i tried starting it back up but it wouldnt at all so we had to steer it in a neighborbood. when we stopped i wanted to start it back up so i did and it seemed to run really loppy its hard to explain and after awhile it would die. so i tried it again and i pushed the gas pedal in and it died. and now when i tried to start it it will stay on for a second and then die. and if i touch the pedal it wont even start it just cranks. i really have no idea what it is please help.
Old Mar 25, 2003 | 01:51 PM
rezinn's Avatar
Sounds like what happened when my ignition module died. Check all the wiring in the area too, something loose can cause bucking and stalling.
Old Mar 25, 2003 | 01:54 PM
IROCafros's Avatar
sorry but. where is the ignition modual located?
Old Mar 25, 2003 | 02:49 PM
IROCafros's Avatar
anything else??
Old Mar 26, 2003 | 09:07 PM
camaro03's Avatar
Car: 1982 camaro
Engine: built 355 chevy
Transmission: th 350 w/ 3.73 gears
this might be to simple, but make sure your getting gas you may have a clogged fuel filter, bad fuel pump, something may be off with your carb, if all else fails, pull a plug and see how it looks, go from there
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
