Project planing
Old Mar 25, 2003 | 07:33 PM
Rage13's Avatar
Car: 89 Firebird
Project planing
What kinda setups (motor, trans., rearend) are good for long road races, like the silver state challenge?
Old Mar 25, 2003 | 08:16 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
something that handles sustained running with a large oil pan...and a good od tranny
Old Mar 25, 2003 | 09:33 PM
Rage13's Avatar
Car: 89 Firebird
well i've figured that much i'm looking at either a 305, 350, or 383 and i'm most likely going to go with an 8speed auto tranny or manual 6, but have no clue on the rear sofar..
Old Mar 25, 2003 | 09:59 PM
Vader's Avatar
Taking a page from NASCAR/Watkins Glen (or more regionally, Elkhart Lake):
  • No rear gears over 3.23, unless the longest straight stretch is less than half a mile;
  • You'll want slightly wider ring gaps for the sustained higher RPM;
  • Extra oil capacity;
  • An auxilliary oil cooler;
  • Baffles or trap doors in the sump;
  • Baffles in the fuel tank;
  • Extra cooling capacity for both the engine and transmission;
  • Less valve lift and more valve diameter to achieve flows - nothing over 0.600" lifts;
  • Lightweight valve train components;
  • Lower stall speed TC (unlike a ¼-mile setup). High slippage causes more heat;
  • Lightweight wheels and tires, with a high heat rejection rate;
  • A front air dam and side air skirts to keep the air from under the vehicle - keep the rear open;
  • Larger brake discs and ceramic brake pads;
I'm sure you;ll get more opinions.
Old Mar 26, 2003 | 07:18 PM
Rage13's Avatar
Car: 89 Firebird
did they make any 4th gen fuel tanks with baffles?
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
