anyone using this cam
Old Mar 25, 2003 | 09:31 PM
TA88GTA's Avatar
Comp Cams Extreme Engery 282 hydro roller
Here are the specs:
Dur. intake-230 exhaust-236
lift intake-.510 exhaust-.520 with a 1.5rocker
Im looking in to swapping this cam in, and just wanted your opinions on it. My mods are as follows:
-355 with 9.5 to 1 compression
-holley stealth ram
-edelbrock preformer rpm heads
-full exhaust
-full msd ignition
-holley DFI
-2500 stall
How well do you guys think it will work with my combo. Thanks in advance.
Old Mar 26, 2003 | 07:49 PM
TA88GTA's Avatar
ttt
Old Mar 26, 2003 | 08:02 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I am using it in a 400 with some other heads and alot more compression than that. It runs pretty hard.
You'll want more stall. Getting it to idle will be a bit of a chore, but probably worth it. You should be able to nearly max out the Stealth Ram with that combo, at around 425 HP or so, if you can get it tuned.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
