engine pings at high rpms, advance or retard timing?
Old Mar 25, 2003 | 10:58 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
subject says it all.. i have lots of pinging at above 5 grand which way should i go with the timing? how many degrees? which way should i turn the dist?
Old Mar 25, 2003 | 11:08 PM
Iroc n roll's Avatar
I'm guessing this car is modded. Rule of thumb is whenever you experience detonation, retard the timing. If you car is modded you should burn a chip to control timing. If you just rebuilt your motor and lost the timing you once had and are now trying to set it from scratch back it off a bit you are too advanced. But the right way to do it is in the chip if you've modded your car.
Old Mar 25, 2003 | 11:17 PM
89RsPower!'s Avatar
its carbed with no comp controls, guess i shoulda started out sayin that.. yeah its pretty modded.. all forged internals balanced and blue printed.. doesnt detonate until around 5200 or so but it ****s at 6500 at wot..guess i'll try retarding it a few degrees n see what happens
Old Mar 26, 2003 | 12:51 AM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
It's been a while but I'll take a stab at it. I'd check initial and total timing first. I think total s/b about 36. To adj, counter clockwise would advance, clockwise retard. Other things: Are you getting a good spark? what c/r do you have? what octane is your gas? maybe add some octane booster or go the next jet size richer on your secondaries and see what happens. Hope this helps, if not feel free to call me a dumba$$.
Old Mar 26, 2003 | 01:57 AM
89' RS/blue's Avatar
Car: 1989 RS Camaro
when i originally got my car smogged it was pinging at high rpms, the mechanic said my timing was advanced by 7 degrees. So i'd definitely retard the timing some.
theshackle
Sep 17, 2020 08:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
