need urgent help
Old Mar 27, 2003 | 01:27 PM
85NJTA's Avatar
need urgent help
cars been in the garage since i bought it last spring, finally getting to change to oil and filter( i know why so long well i havent been driving it) and i drained the oil and the shop or previous owner tightened the filter on too tight and after struggling with it for the last thirty minutes i friggin punctured it...( i got a little frustrated)...whats the best way to loosen it so i can change it and refill the oil...
Old Mar 27, 2003 | 01:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Rip the whole sheet-metal shell off, and use a chisel or something to tap the thick metal base that remains, to unscrew it.
Old Mar 27, 2003 | 01:41 PM
85NJTA's Avatar
ok, i'll try that thanx
Old Mar 27, 2003 | 01:47 PM
ERICK87Z28's Avatar
Car: 1988 IROC
Engine: 5.7 HO TPI
Transmission: 4 spd Auto
Or grab onto it with a big pair of channel-locks, or similar plier-type wrench, and reef on it. Doesnt matter if it gets destroyed in the process.
Old Mar 27, 2003 | 01:51 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Hammer a screw driver through the side of the filter, and try and turn it.
Old Mar 27, 2003 | 03:11 PM
85NJTA's Avatar
f'er still wont budge..i got half the shell off, attempted to use the biggest pair of channel locks i have to bust it off and it still wont come off....this t/a has been nothing but aggrevation...any other ideas before i give and lose it and call a junker..lol
Old Mar 27, 2003 | 03:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Rip the rest of the shell off, use a BFH and a screwdiver or large chisel to drive the thick metal plate in a CCW direction
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
chisel time..just be careful when you get throught the rim of the filter so as to not damage the mounting spot
Old Mar 27, 2003 | 04:14 PM
85NJTA's Avatar
well, the chisel/screwdriver method seems to be working, sorta...my arm is about to fall off or i am weak cuz theres not alot room to get leverage with the hammer so i am gonna be pounding for a while...just need to rest the arm. lol....but thanx for all the help guys, you help me not feel like such a dumbass
Old Mar 27, 2003 | 04:15 PM
Axle/Gears: 3:08
sharpen the chisel or heat it with a torch..will go through easier
Old Mar 27, 2003 | 04:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You're not trying to cut anything, all you need to do is get the chisel to hang on a projection from the metal or one of the holes in the plate or something, and then tap on the chisel to unscrew the bottom plate of the filter. Should come loose with a couple of whacks, then it will be loose enough to spin the rest of the way off by hand.
Old Mar 27, 2003 | 04:28 PM
Axle/Gears: 3:08
if the rim of the filter seized to the filter mount..he will be trying to cut something off...had it happen on a car...
Old Mar 27, 2003 | 04:33 PM
85NJTA's Avatar
i am trying to put the chisel in the holes around the main hole where the filter screws on and tryig to loosing that way....i just sprayed penatrating oil
Old Mar 28, 2003 | 01:13 PM
85NJTA's Avatar
Nope, no f'ing luck...this is major agrevation...i took the entire shell and guts off the filter, and with a chisel and screwdriver and ballpeen hammer spent all afternoon yesterday trying to loosen the filterbase ccw...this morning spent an hour with a hairdryer trying to heat the filter base so it would expand...nope....if i cant get this f*@ker off i cant drive it to the shop for other work i was gonna do and am about to take the sledge hammer to the car..
Old Mar 28, 2003 | 11:27 PM
hank's Avatar
There should be a ring on the top of the filter where the top and the side are sealed up on assembly like RB said use a hammer and a chisel you don't want to cut the ring you just want to walk it off with the chisel your just using the chisel to grip the metal i don't think a hairdryer is hot enough to expand the metal just a thought if you have any electical contact cleaner you might be able to use it on the rubber ring it might free it up a little i would ithink it would be like using a torch to cut a lock washer to relieve pressure on a stuck bolt just a thought never tried it on oil filter the tightest one i had i got it off with a screw driver later just a piece of advice and this is something i also tell myself is to DO NOT work on anythng Angry you just end up f!@ckin it up worse or breaking something else take five walk away and everything will work out fine
Old Mar 29, 2003 | 01:29 AM
rjmcgee's Avatar
I know that this doesn't help you now, but in the future buy one of those nylon strap oil filter wrenches. They have always worked very good for me.
Old Mar 29, 2003 | 11:55 AM
85NJTA's Avatar
Well...thanx for the help everybody...i actually got the filter off, when dad got home, he looked at it and went in the garage, jimmy rigged a spanner wrench with a couple pegboard hangers and took a hammer and got it off..so when i replaced it i made sure it was only hand tight now i just need to get a spanner wrench and one of those sears belt wrenches...well its off to the suspension shop for a front end job
CALIROCZ28
Sep 26, 2004 05:47 PM
CALIROCZ28
Northern California
Feb 29, 2004 07:32 PM
CALIROCZ28
Southern California Area
Feb 27, 2004 12:43 AM
