gear oil question
Old Mar 27, 2003 | 06:06 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
gear oil question
i have a leaking pinion seal and i am going to take it out to my buddies house on sunday to replace the seal. now, at work we use exxon synthetic 80w-140 gear oil in our rears( eighteen-wheelers). can i top off my car with it just to drive it like 30 miles to my buddies house? i live in apartments and we cannot work on cars over here, so i just use my buddies shop. i noticed richmond sells a 75w-140 gear oil and thats why i was wondering if its ok to use it. can it be used all the time??? thanks
Old Mar 27, 2003 | 06:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It should be OK. You could probably use that as the fill fluid, it would just cost you some RWHP and gas mileage. But it won't hurt anything.
Old Mar 27, 2003 | 06:12 PM
bubbz89's Avatar
Car: 1990 RS
how does it affect mpg and rwhp? thanks for info btw, we have several 55 gallon drums at the shop. good to know i can use it. btw, do i fill it up till it comes out of the plug hole?
Old Mar 27, 2003 | 06:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, that's what you do.
It's thicker, and doesn't lube as well as synthetic in particular, so you just end up with more loss in the driveline. The motor does some extra work that doesn't make it to the wheels.
Old Mar 27, 2003 | 06:33 PM
rumpilstiltskin's Avatar
My posi has been acting up and not locking up when going staight. I was wondering if i'm low on gear oil in my rear. What weight should i fill it with? I live near cincinnat ohio so its about 50-70 now, and will get up to about 80-90 over the summer, if temperature matters.
Old Mar 27, 2003 | 09:03 PM
bubbz89's Avatar
Car: 1990 RS
i think 75w-90, but i am not sure
Navy8125
Aug 21, 2015 09:32 AM
ezobens
Aug 19, 2015 10:29 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
