Roller rocker alignment
Old Mar 28, 2003 | 04:03 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
While installing my rocker arms (pro mags) I noticed the roller (non-self-aligning type) doesn't center itself over the valve tip (side-to-side wise).
I've been loosening the studs and moving the guide plates around, but I'm still unable to get the rockers centered.
I can get one rocker centered, but the other will be off a little.
To make them perfect, looks like I'll need different guide plates.
For now, I've split the difference between the intake and exhaust valves.
Does it need to be perfect??
BTW; the guide plates are made by Sealed Power.
Old Mar 28, 2003 | 05:56 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are designed to be like that.
The purpose is so that the rocker will be slightly off-centered, to make the valve tend to rotate.
Old Mar 28, 2003 | 05:52 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Learned something new.
Thx RB.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
meeklay812
Oct 1, 2015 03:46 PM
