i need some help guys
Old Mar 29, 2003 | 04:21 PM
91fbirdgta's Avatar
Car: 91 Firebird GTA
whats up guys, not in the best mood right now-got a real confusing problem-I took my car to the dealership the other day to have to car taken care of (replaced the whole intake gasket) took 2 days in the shop; get the car back, and when i beep my alarm (viper-2 buttons) the headlights go up a little, and back down with the lights (the lights are suppose to blink, but the headlights never/aren't suppose to go up and down-i've had the alarm on the car for a year now . . .so i don't think thats the problem-but i will have that checked . . . .
also, when i push in the parking light switch, the headlights come up (not on) and that never happened . . .
well, the next day i took the car back, and made them inspect it and they couldn't figure it out, now i'm stuck w/ this friggin problem!
anyone ever had this happen to them before or have any idea whats wrong with the car?!?!? any info would be appreciated
Old Apr 2, 2003 | 02:19 PM
91fbirdgta's Avatar
no one has any ideas?!?!?!?!?
Old Apr 2, 2003 | 03:12 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
They might have got the wrong wire when they went to the switch for the parking light flash. Look to see where the white wire from the alarm goes, then check the wiring diagram for your car and see if they got the right one. If you don't have a wiring diagram I can look it up for you.
Later,
Matt
Old Apr 3, 2003 | 04:55 PM
91fbirdgta's Avatar
thanks matt, yea its a viper alarm-had it now for about a year! so i don't know if thats whats doing it-i replaced the whole headlight/parking switch-and thats not it . . .so its either the alarm, or what some jackass at the dealership did to my car (technically, shouldn't they be responsible and fix it?)
i made an appointment this sat. w/ the company that installed the alarm so i'll keep this post up
btw, does anyone know if the viper sys. has a master reset button type of a deal?!?! thanks
any one else w/ ideas!!?!?!
Old Apr 11, 2003 | 06:30 PM
ScreaminChicken's Avatar
This same sorta thing happened to my '92 Formula which had an Ungo alarm installed in '92. It was 9 years old and one day when I disarmed my alarm, the headlights popped up(but the lights didn't turn on). The difference is with mine the headlights wouldn't go back down. I could turn the lights on and off, but they'd never pop back down. Even when I stopped and manually cranked 'em down, as soon as I started my car(never touching the alarm this whole time) the lights would pop back up again. I finally disconnected my alarm and the lights have worked regularly ever since Sounds like your alarm has gone bad (at least as far as making your headlights act weird).
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
