Installing Roller Rockers
Old Mar 29, 2003 | 07:13 PM
Acidtalons's Avatar
I have a set of scorpion 1.6 roller rocker arms I am trying to install, however the rocker arm studs don't seem to be long enough.
When I place the rocker arm on the stud, over the pushrod and the valve tip the thread on the stud barely sticks out, not enough to attach the nut.
Is there something I am overlooking?
Old Mar 29, 2003 | 09:03 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Are they all like that?
It's normal if the valve is supposed to be open, but that would only be on a couple of valves at any one time.
Pushrods may be too long for the rockers.
Old Mar 30, 2003 | 08:22 PM
Acidtalons's Avatar
Turns out the shop I goto accidently gave me the wrong length studs. Standard rocker arms need 1.9" studs but roller rockers need 2.1 inch studs.
Old Mar 30, 2003 | 08:32 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Gains??
Hi,
I was just thinking of asking this very question, Will 1.6 rollor rockers make THAT much of a difference on a stock eng??
EX I have a 92 5.7 tpi and was conscidering this upgrade provided it will not cause problems ex idle and clearance problems , replies??..............GTA....
Old Mar 31, 2003 | 01:33 AM
Acidtalons's Avatar
10% more cam lift and alot less friction.
Hot Rod swapped Comp Cam Magnum 1.5 Roller tip rockers onto a 350 a couple issues back and got 16hp, 24hp with 1.6s. I am switching over to a full roller rocker which has a roller trunion, instead of a pivot nut, as well as a roller tip. Only problem so far has been the need for taller rocker studs, potentially switching to a 1.6 could cause a piston to valve clearance issue but this is not usually the case.
To check piston to valve clearance just put some clay on top of the piston, put the head on without the gasket and then roll the engine over twice. Measure the indents in the clay then add the thickness of the gasket your gonna use and thats your clearance.
Also roller tip rocker arms will increase your fuel economy by as much as 5% according to GM research and also increases valve train service life.
Mickeyruder
Sep 2, 2015 02:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
IrocZ'85
Aug 17, 2015 06:24 PM
