Spark Plugs
Old Mar 29, 2003 | 01:59 PM
1982Camaro383's Avatar
Spark Plugs
I have a 1982 Camaro with a built up 350 Chevy, I am using GM Performance Parts Drilled and Tapped Vortec heads. What spark plugs do you guys recommend. I have an all MSD Ignition system. I am currently using NGK's debating on trying. Accell Header plugs. What do you guys suggest. I have tried ACDelco, Champion, platinum, not really happy with results. Any ideas, my setup is on my website at http://www.fbody.com/members/82Camaro.
Thanks,
Justin
1982 Camaro 350
Old Mar 29, 2003 | 03:00 PM
Vader's Avatar
NGK makes very good spark plugs. They have an excellent ceramics development program. As long as you can fit in the regular length pure platinum plugs, I'd stick with them. If you're worried about heat on the wires, try installing some of the aluminum plug boot shields from LT1/4 engines.
Old Mar 30, 2003 | 04:09 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If you're having that much trouble with plugs, you have some other problem.
I use Champion RS12YC.. Inspected them after two years use
still good. reinstalled them.
Finally changed to Cham RS10YC's put the 12YC's in the tool box for spares. Cause they are still good after 3 yrs.
You have some other problem like carburaton or something causing your plugs to foul.
F-BIRD'88's Avatar
the right way
Old Mar 31, 2003 | 04:54 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I agree. ACDelco's are good plugs and they should work great.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
