Injector help ASAP !
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Im currently in the process of installing my HSR, and while Ive got the injectors out, I decided to test them for resistance and consistancy. Seven of the eight injectors are at a consistant 16-16.2 ohms, but one is at only 8 ohms. It is possible that one was dropped during disassembly, whether this damaged it or had an effect on its winding resistance, Im not really sure. My question is, will the engine run properly with this injector, is it useable until I can buy a set later, or does it have to be replaced now? Thanks in advance.
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Your going to need to replace that injector before you reassemble your engine. Dont even bother putting that back in because it will not run right.
